09'ABS wheels on non ABS 09'
Old 10-03-2010 | 10:36 AM
DPete's Avatar
DPete
Big Kahuna HDF Member
Default 09'ABS wheels on non ABS 09'
Will they bolt up? Bought a set of low mile stock wheels & tires as far as I can tell the ABS bearing is the only difference and should bolt up in place of my non ABS
Old 10-03-2010 | 10:40 AM
flhxkiller's Avatar
flhxkiller
bearings are only difference on ABS equipped bikes, I'm thinking you can use abs bearings on a non abs bike just not vice versa due to the sensors in the bearings.
Old 10-03-2010 | 10:45 AM
DPete's Avatar
DPete
Ya , that's what I'm thinkin
Old 10-03-2010 | 02:24 PM
DPete's Avatar
DPete
bump, anybody done it?
Old 10-03-2010 | 05:28 PM
cooper57M's Avatar
cooper57M
I just removed a ABS bearing out of a 08 wheel and installed Non ABS bearing. There is a width difference between the two bearings.
Old 10-03-2010 | 08:20 PM
DPete's Avatar
DPete
Mmmmm, if there is a difference in width the spacer might not be right, guess I'll just change out the ABS for non like you did
mikeo33y
03-10-2023 05:06 PM
dgoodbmw
07-26-2017 10:10 AM
WILDWOOD_1124
06-26-2014 02:06 PM
BJFLHT
08-10-2012 10:46 AM
Titan56
03-25-2012 09:23 PM
Quick Reply: 09'ABS wheels on non ABS 09'
