What is lugging?
What is lugging?
There seems to be a lot of misunderstanding about what this is.
"To run poorly or hesitate because of strain."
I came across the following statement on the subject:
The cause of the strain or resistance is just as important as rpm and gear to determine a lugging situation. 6th gear at 55 mph (2000 rpms) is not necessary lugging if you are on a decline. 6th gear and 75 mpg (2800 rpms) might be consider lugging if you are on a steep incline. It is all relative to the resistance which can be caused by wind, road topography and load. It is the ability of the engine to produce power to overcome that resistance without undo strain. Granted that higher rpms produce more torque so it safe to say that a higher rpm is less likely to be lugging the engine. That doesn't mean operating at a lower rpm is lugging.
RE: What is lugging?
Great point, when on level or downhill situations lower RPM's don't 'automatically' lug the engine as there are very limited resistive forces to counter an increase in acceleration. The same exact speed and RPM at the head of an incline would produce drastically different results in that your engine now has to also achieve more work due to climbing where momentum is greatly reduced.
6o66er
03-23-2008 08:17 PM
