FatCat 2-1 baffles
FatCat 2-1 baffles
I thought the wrapped baffle was too loud so i ordered the wrapped concentric 159.00. The wrapped baffle was wide open if you looked up in the exhaust you could see the two open headpipes. Anyone change to the wrapped concentric? D&D said it is for just a stock motor but i think it flows more than a nightstick slipon with a stock gutted headpipe. Talk about fun getting a baffle out of a FatCat. I used a belt sander and rolled the new baffle on it so it pushes in there easier not dealing with that fit again.
Per Leonard at D&D (I realize he's gone, but this is still the company line), the concentric baffle is for nothing more radical than a Stage 1 96. When I told them I was running it on my FLHTK, they exchanged it for a wrapped perforated baffle....and damn near insisted that I take it. It's certainly louder at idle and cruise, but not obnoxious.
Leonards gone?
Where did he go? I spoke with Fuel Moto and they said that the wrapped concentric flows well and i did not need a map change going from the wrapped perforated. Ill bet that it flows as well as some of the other systems people are using on non stock motors. It felt like i lost some low end with the wrapped perforated .
I imagine putting a more restrictive baffle in would not require a retune just as Jamie from Fuelmoto has stated. Least it did not on my bike.
The bike might have run a little richer but not enough to require a dyno run or retune. I'll go with what Jamie says...cause it makes sense.
lp
Baffle changes
Well i hope that its not that big of a problem i just want it a little quieter and am using a pcv now. I have the SE tuner with Smarttune but haven't tried that yet. I just want it to sound and run half decent not trying to extract every ounce of power out of it.
No, different pipe on the 07. That pipe was quiet compared to the Fat Cat for the 09+... I've had both and the 09 pipe with the "standard" baffle will blow your ears out. The wrapped baffle was only a tad bit quieter. Still friggin loud. The Concentric baffle is much quieter.
lp
lp
