FLHX vibration
#31
#32
From what I understand, the vibration is just a characteristic of the Street Glide, regardless of whether it's new or not. I just ordered a Glide-Pro front motor mount for my 2008 FLHX. Others (as well as the guy who makes them) have said that it will make a HUGE difference and should eliminate the vibration. Check out the install video and the before & after.
http://www.glide-pro.com/install/
http://www.glide-pro.com/stabilizing-system/
#34
#35
This other dealer adjusted the plastic tab and tightened the clutch cable. Still there but not as bad.
Fuzzy...
#36
#37
Update
Just got a call from the dealer. Said they tightened the handlebar clamp, moved the wires that were bound near the rubber under the handlebars (thinks that what causing the sqealing noise) and tightened and tie wrapped loose stuff inside the fairing. Told me the tech rode the bike about 15 miles and said the issue appears to be solved.
I'm going to pick the bike up on Thursday due to rain today and tomorrow. Will follow up with my verdict then.
I hope it's solved and I'm not disappointed.
#38
#39
Thanks for the update, very glad it worked out. I'll ask my dealer to do the same and hope for the same results. Ride safe..
Fuzzy...
