FLHX vibration
Old 04-12-2011, 10:57 AM
dc1057's Avatar
dc1057
dc1057 is offline
Fuzzy-1
I've been having the same issue. Did you find a cure? Mine is going in to the dealer next week to have the issue checked out. Would like to have a sense of direction, just in case.
Thanks.
Old 04-12-2011, 11:26 AM
garand's Avatar
garand
garand is offline
The left side of my handlebar shakes too! It gets annoying when I take my hand off and I can hear the lever shaking? Am I going to take it to the dealer? No. I'm going to keep on riding and not givin' a $hit about it.
Old 04-12-2011, 11:30 AM
Thatzmister2u's Avatar
Thatzmister2u
Thatzmister2u is offline
Huh, go figure mines on the right. Actually shakes so hard the passenger peg won't stay folded up an neither will the highway peg on crash bar. Dealer? nORMAL! WTF
Old 04-12-2011, 04:47 PM
Fuzzy-1's Avatar
Fuzzy-1
Fuzzy-1 is offline
Originally Posted by dc1057
Fuzzy-1
Thanks.
Dc1057;
After the the 1K service at the dealer the left handlebar was much smoother but still vibrates. that was 1700 mikes ago. I am taking it to another dealer tomorrow to address some unwanted decel pops and I will ask them about the clutch lever. To me it looks like too much free-play where the clutch lever connects. Meaning if where the lever connects to the handlebar was a little thicker or the clutch line was a little tighter, it would pretty much eliminate it.
Fuzzy...
Old 04-12-2011, 07:01 PM
dc1057's Avatar
dc1057
dc1057 is offline
Fuzzy-1
I guess I mis understood your first post. I thought your handlebars were vibrating so much your clutch lever was making noise? The handlebar vibration is the issue with mine. That's the cause of the squealing noise when I let go of them.
Did you ever get a response to that concern from the dealer?
DC
Old 04-12-2011, 07:18 PM
SG Guy's Avatar
SG Guy
SG Guy is offline
I'd be interested in the solution, too. I have 2006 street glide that vibrates like a mad man. Left side is very noticeable.
Old 04-12-2011, 08:15 PM
TWIN CAM 96's Avatar
TWIN CAM 96
TWIN CAM 96 is offline
Yeah I'd like to know what causes that!
Old 04-12-2011, 08:28 PM
Fuzzy-1's Avatar
Fuzzy-1
Fuzzy-1 is offline
Fuzzy-1
DC
DC;
Sorry about the confusing post, I went and cleaned the post up a bit. Yes, the 1st dealer said that it is OK . I am taking it to another dealer tomorrow to have them check the popping of the pipes and I will ask them about the left handlebar as well.
Fuzzy...
Old 04-13-2011, 10:03 AM
Hardly Dangerous's Avatar
Hardly Dangerous
Hardly Dangerous is offline
Have you guys checked your front motor mount? Every time I start to get excessive vibration it turn out to be the motor mount.
Old 04-13-2011, 10:29 AM
iwillfixthem4u's Avatar
iwillfixthem4u
iwillfixthem4u is offline
Originally Posted by Bithand1
Is it the grip or just the clutch lever? If it is primarily the clutch lever there is an anti vibration tab integrated into the lever. Look from the end of the lever with the lever at eye level. You may see a little rub mark on the inside bottom of the housing and a silver screw that threads towards the top of lever. Mine did this and it was simply the screw had backed out. Still trying to get it in order. Another issue may be clutch adjustment. I'm fighting that right now as well.
I think Bithand1 hit it on the head.....
Quick Reply: FLHX vibration
