the problem with that pump and ones like it is that it goes up to 300psi with 50lb increments. this is way overkill. There are ones on Ebay like the one listed in this thread earlier that have a max psi of 60. This one would be much better for fine tunning. just my 2 cents.
Damn, didn't read the description. It's worthless for harley shocks.
I realize this is slightly off topic, but does anyone else use the HD air suspension pump to check their tire pressure? I found that the rubber hose fits nicely through one of the slots in my rotor and enables me to check the tire pressure without a problem. Of course I don't use the pump to add air - just to check it. It goes up to 60LB and I guess it is pretty accurate. At least it should be for $47.00.
