Anyone try this Bosch headlamp???
Just wondering if anyone has tried it out and what the results were. Seems like a pretty good deal but if it doesn't make a difference in lighting then it is pointless.
Bosch 7" headlamp
Bosch 7" headlamp
From what I've heard and read , Candlepower doesn't usually handle junk hardware of any sort.
Generally the lense optics have a better pattern than reflector optics (clear glass)do.
Lense optics just aren't "cool" anymore as clear glass looks neater to most people.
A better deal (maybe) would be a Hella E-Code for around $50.00 plus bulb or the Cibie E-Code which has one of the best beam patterns of any headlamps.
I run the Cibie with an Osram 70/65 H4 bulb , it ran just about $100.00 from http://www.danielsternlighting.com/
An impressive headlamp and a very good deal for this kind of performance.
I imagine the Candlepower setup would be an upgrade from stock for sure , the price is right anyway.
Mick
Mick
Mick
Mick
Yeah I was looking at the Hella and came across this. Figured for the price it can't be beat if it gives a better beam pattern. Trying to figure out if it is e-spec or not.
i am using the hella e-code headlight, and it works far better than the stock plastic housed headlight. the light is focussed where we really need it rather than being so spread out like the d.o.t. compliant headlights. i'm very happy with the performance of the hella lamp. the hella is the german company, whereas the cibie is the french manufacturer. susquehanna motorsports has the best price i've found on them. if i remember right, it was 38 bucks for the headlamp housing, and yes, the reflector is glass rather than the cheezy gray plastic chrome plated harley reflector. i actually like the way my hella looks on my bike even when it's turned off. crisp and clear, clean.
I believe this may shed some "light" on the SAE question.
http://www.ratwell.com/technical/BoschH4.html
Looks like the specs are different enough that E-Code won't make the SAE spec and visa versa .
I can tell you the E-Code won't bother oncoming traffic as bad for sure.
The light focus is really that different between the two specs.
Mick
Mick
okay guys, i know, a double post. one thing you need to know, is to get the one that's made for germany or france. the brits drive on the wrong side of the road and the light will be placed to the wrong side of the road if you get the wrong headlamp. clarify this when you order it.
Mick is right. I used Hella lamps in cars years ago before they were legal in the US. The light pattern is what makes them so great. You can see the sharp line of the sculpted beam pattern on the road in front of you. The ones for right lane driving have a "notch" on the left side of the light pattern to avoid blinding oncoming drivers. When I bought the lights I got 55/100 watt H-4 bulbs. The seller said at the time that despite the 100w hi beams I would be more impressed with the low beams. He was right. It's all about the lens optics. BTW don't waste your money on 100w hi beams. The 70/65s are plenty and probably don't require a relay.
