New HD LED Turn Signals
Does any one know if the HD Visor Style Trim Rings will fit on the new HD LED Turn Signals.I have a set of the LEDs on order but I won't be picking them up for a couple weeks.I'd like to use the visors on them that I now have on the front and rear turn signals.
Thanks
Dan.
Thanks
Dan.
You could always just pick up LED clusters from Custom Dynamics and not have to worry about fit with the trim rings. Super bright and lifetime warranty. And you can do front and rear for the price of one set of the HD LED's.
Custom Dynamics LED Turn Signals
Just food for thought.
I bought & installed the LED front signals last week because I dont have visors on the front although the stock lens screws up front are side to side. I didnt do the rears because the rear visors and stock lens screws are located top & bottom not side to side. I think the front visors may work with the new front signals but not the rears. It also may depend on what visors you have. I know this is not a definite answer but please post what your outcome is. I would like to install the new rear signals with visors.
I picked up the HD LED turn signals on the weekend and I installed the rear this week.I wasn't going to hook up the run mode but I gave it a try and they are the same brightness as the LED Tailight.I'm leaving them wired that way.I found that the regular bulbs with the Run/Brake module were too bright as running lights and not enough difference between run and brake.The LEDs have a big difference between run and brake,and the signal mode is very bright.I have the fender tip LED light as a brake and run as well,so I should get their attention now.I had questioned a few weeks ago if the HD visor trim rings would fit on these LEDs,and yes they will.I have the front LEDS as well,but I'll wait to install them when I install my HD Boom fairing speakers which I'm getting for Xmas.I'm a happy camper.Sorry no pictures.
Installed the rear HD LED turn signals and HD Bar & Shield LED tail light today. Wired signals as run brake turn per instructions. Had to remove the run brake turn module I installed last year for them to work properly. The combination is a much brighter improvement. I got visors off e-bay that match the old rear visors I had, they were only held on with one srew on the top, to work with the new rear turn signals.
