Is a tune required?
Personally no you don't need too.
Do your research. Try tuneyourharley.com read, read, read, read.
Of course your pipes turned blue all pipes will, it is a natural chemical reaction of metal to heat. 300 - 700 degrees.
For all those professing a tune, a power commander or anything else;
Where is the documented proof? Not the I heard from a friend blah, blah, or my indy says so, or I read it on the forum and by gawd that's gospel.
Show us in writing mechanical proof, charts, independent research by a reliable source.
Not trying to be a wiener but backyard mechanics and hearsay evidence doesn't make a very good case for belief.
Nothing more than inline resistors fooling the ecm.
I believe you changed your tone in mid-stream, but to answer your initial question, if you're just changing exhaust you dont need to change anything else. You'll still be running "factory lean", which I don't reccomend, but you'll be okay. Add a a high-flow air cleaner and you'll definitely need a fuel management system.
Guess I shouldn't be amazed with all the different opinions. Appreciate all the advise. I was just really looking for loader sound and caught a good deal on pipes. In the process didnt want to sacrifice the sound, and cause damage to the bike. I understand that dyno tuning is the best procedure, but considering most say nothing is required when changing exhaust, think the AC/PCIII I just ordered is a step in the right direction. When I spoke with the guy at fuel moto (who is recommended on this board) he knew exactly what I needed. Thanks again everyone
