Hiding The Throttle Wiring Plugs / Harness At The Intake
Old 09-28-2010, 05:56 AM
homerandpooh's Avatar
homerandpooh
homerandpooh is offline
Default Hiding The Throttle Wiring Plugs / Harness At The Intake
I plan on going with the exposed filter look for my intake. The only thing the football cover was good for was hiding that ugly throttle plug. Anyone come up with a cover or solution to hide that?
Old 09-28-2010, 06:38 AM
toby34's Avatar
toby34
toby34 is offline
there are two companys out there that make a cover for this eye sore. kuryakyn is one part number 8657 chrome only. the other not sure at this time. If you use the harley run of the mill big breather it has one included in the kit
Old 09-28-2010, 09:10 AM
homerandpooh
Thanks, I had no idea that Kuryakyn made a part for this. It is definately an option.
Old 09-28-2010, 09:27 AM
Ctac's Avatar
Ctac
Ctac is offline
Old 09-28-2010, 09:30 AM
homerandpooh
I'm not sure I like the unbalanced look of it. My main concern was only in covering the harness.
Old 09-28-2010, 09:54 AM
DrPlastic's Avatar
DrPlastic
DrPlastic is offline
I just disconnected the plug and re-routed the harness over the top of the throttle body, it is much less visable! If left routed under the throttle body it hangs down and is definately an eyesore.
Old 09-28-2010, 11:38 AM
rome304's Avatar
rome304
rome304 is offline
went this route
Attached Thumbnails Hiding The Throttle Wiring Plugs / Harness At The Intake-picture-10-14-08-149.jpg
Old 09-28-2010, 11:42 AM
homerandpooh
Rome, yours is throttle by cable and doesn't have the harness.
Old 09-28-2010, 04:18 PM
Stang951's Avatar
Stang951
Stang951 is offline
You can also get the part that covers the servo from the SE Filter kit.
I cant remember the part number but if you look at the part online you should be able to get the parts list from the installation instructions.
Old 09-28-2010, 05:09 PM
DrPlastic's Avatar
DrPlastic
I think he is talking about these
Cover, throttle body, wrinkle black (Kit 29253-08A) 29009-08
Cover, throttle body, gloss black (Kit 29006-09A) 28890-09
Quick Reply: Hiding The Throttle Wiring Plugs / Harness At The Intake
