what air pressure in rear shocks?
Old 09-28-2010 | 04:50 AM
desertwolf's Avatar
desertwolf
Default what air pressure in rear shocks?
New to Street Glides and just wondering what air pressure people are running? I'm right around 200lbs and just trying to get an idea of where to start. Thanks
Old 09-28-2010 | 06:28 AM
DrPlastic's Avatar
DrPlastic
It all depends on the weight the bike is carrying and whether or not you are riding solo or two up. check the owners manual. get a HD air pump. do not use air compressors and bicycle pumps as they will cause permanent damage.
Old 09-28-2010 | 06:40 AM
thecort's Avatar
thecort
Solo rider around 10-15psi, depending on weight. I tried 30psi riding just myself (200lbs) it helped out with the shock feeling as if it were bottoming out but the downside is it also rebounded a lot harder causing me to lift off the seat! The bike is fantastic but I'm NOT a fan of these shocks AT ALL! If I wanted to ride a Rigid I would have bought a Rigid.
Old 09-28-2010 | 06:54 AM
shortride's Avatar
shortride
I weigh 260 lbs and run about 20 psi in the rear shocks.
Old 09-28-2010 | 07:28 AM
scheduler's Avatar
scheduler
The wife rides here SG with 5 psi and that softens up the rear without bottom out
Old 09-28-2010 | 07:55 AM
Dino M's Avatar
Dino M
I'm about 280lbs and I keep them around 20lbs. When the wife hops on, I'll put another 5 - 10 lbs in them.
I agree with DrPlastic too. Buy the HD pump and keep it in your saddle bag. It's easy to use and you can play around with different psi's during your ride.
Old 09-28-2010 | 08:48 AM
Ridewva's Avatar
Ridewva
I run about 35 running solo, 40 when loaded down on a trip, 50 with a passenger. I believe this is about what the manual suggests.
Old 09-28-2010 | 08:53 AM
Jags93's Avatar
Jags93
I'm 175 lbs and currnetly running 11 psi. 16 psi was too rough. 11 is much better. No bottoming out yet at that level.
Old 09-28-2010 | 08:59 AM
BADBREW's Avatar
BADBREW
I'm about 200lbs, GF about 125lbs. Run 35lbs with both of us, about 20lbs solo. When I run 25lbs 2 up we bottom out on big bridge transitions or bad roads. Lots of twisties here in East TN. This air pressure works good around here for the type of roads and the road conditions, need stiffer suspension, would be too much on flatter land. I keep the HD pump in my saddlebags to adjust as needed when we ride other parts of the country.
Old 09-28-2010 | 11:58 AM
TxCowboy's Avatar
TxCowboy
On my Ultra Limited, I run 28 psi with me at 185 pounds and about 20 pounds of gear in the bike.
When the wife climbs about, we run it at 45 psi with her 110 pounds and her 20 pound purse added to the weight.
The bike seems much more stable at these pressures, had never bottomed out (that I know of), gives a good "feel of the road", and performs well on both hightways and rural roads.
Quick Reply: what air pressure in rear shocks?
