07 Classic where's the O2 sensors?
Old 09-26-2010, 07:51 PM
Bogey_52's Avatar
Bogey_52
Bogey_52 is offline
Default 07 Classic where's the O2 sensors?
I just purchased a used 07 FLHTC from a dealer and started checking it out when I got home. It has stock exhaust and where the O2 sensors go in the headers there are plugs. I pulled the seat and both side covers and I dont see an EFI tuner of any kind. Near as I can tell everything looks stock. Is there a way to bypass the O2 sensors? What should I be looking for? Did all 07's come with O2 sensors?
Thanks,
Bogey
Old 09-26-2010, 08:00 PM
stro1965's Avatar
stro1965
stro1965 is offline
Yes, you should have O2 sensors. I'd guess that there is a PCIII hidden in there somewhere.
Old 09-26-2010, 08:15 PM
nvsteve's Avatar
nvsteve
nvsteve is offline
Thanks,
Bogey
Sounds like the sensors have been removed.
The only unit that I'm aware of that eliminates the sensors is the Power Commander. If that's the case you should find the ends of cables with eliminators attached. The standard mounting position for a PC on 07 touring bikes is under the right side cover.
Old 09-26-2010, 09:07 PM
hogginit's Avatar
hogginit
hogginit is offline
Would not be unusual for the previous owner to remove the PC and take off the eliminators also.
Old 09-26-2010, 09:14 PM
07RoadHawg's Avatar
07RoadHawg
07RoadHawg is offline
That's a strong possibility. The other thing I can think of that uses O2 eliminators is the DFO or Techlusion TFI. It goes by a couple of different names. It's a device that goes inline between the ECM and fuel injectors. Typically it's a small box that would be under the seat in the spot at the base of the tank. There would be wires that plug in to the injectors under the tank. You should be able to see the eliminators plugged in to the original O2 sensor wire though.
Old 09-27-2010, 08:05 AM
Bogey_52's Avatar
Bogey_52
Bogey_52 is offline
Thanks for the advice 07RoadHawg. I'm gonna lift the seat again and check out those connectors and look for eliminators after work today.
Old 09-27-2010, 09:47 AM
stro1965's Avatar
stro1965
stro1965 is offline
He'd be throwing codes though, wouldn't he? If the PCIII and the eliminators had been removed and the O2 sensors not been replaced?
Old 09-27-2010, 02:28 PM
Bogey_52's Avatar
Bogey_52
Bogey_52 is offline
I'm not getting any codes and I think the thing runs great so I'm guessing it has the O2 sensor eliminators and some type of tuner. Does a PCIII replace the computer or piggyback onto it? And I would guess it would have a label of some kind so I could ID it. Everything looks stock MoCo under the side covers. I'm not bitching, just would like to know what I got.
Old 09-27-2010, 02:31 PM
Bogey_52's Avatar
Bogey_52
Bogey_52 is offline
I had a Dobeck/Techlusion DFO in my 97 E'Glide. I know how they hook up. Didn't see any evidence of one of those either. BTW I thought they worked great. Like tweaking a carburetor.
Old 09-27-2010, 02:50 PM
nvsteve's Avatar
nvsteve
nvsteve is offline
A PC piggy backs and on 07's instructions were to mount int right on top of the ECM which is behind the right side cover.
snkebyt
03-07-2010 08:32 AM
trevd
04-08-2008 09:12 AM
07flstc
11-23-2007 03:10 PM
mistermooster
02-24-2007 07:24 PM
aal
10-11-2006 12:34 AM
Quick Reply: 07 Classic where's the O2 sensors?
