Shorter Antenna on Electra Glide Classic
Old 12-04-2004, 02:41 PM
hyflyer's Avatar
hyflyer
hyflyer is offline
2nd Gear
Default Shorter Antenna on Electra Glide Classic
Where can I find a short antenna mast to replace the long Am/Fm factory antenna on my Eletra Glide Classic?
Old 12-05-2004, 12:08 PM
luvmyflhtcui's Avatar
luvmyflhtcui
luvmyflhtcui is offline
Default RE: Shorter Antenna on Electra Glide Classic
Harley makes a shorter antenna that is part of the relocation kit for when you remove the tour pack and ride without it. Check with them and see if they can order you a shorter one. You can also try taking your antenna to Radio Shack and see if they have one that will screw onto your bike.
Old 12-05-2004, 02:33 PM
y2kfs68's Avatar
y2kfs68
y2kfs68 is offline
Ive seen the short flexible antennas on some rides. Never looked into it myself as a long antenna helps me find my ride when leaving the bar.
Old 12-14-2004, 12:14 AM
h2000fb's Avatar
h2000fb
h2000fb is offline
Stage III
Hyflyer,
Go to any automotive store, buy any of the screw-antennas. They will work. I tried the short rubber ducks, standard GM/Ford antennas, and checked them for proper impedence. They all tested fine. The best reception came from the standard GM truck type antenna. It outperformed the large Harley whip!!
Old 12-31-2004, 12:06 AM
Road Nazi's Avatar
Road Nazi
Road Nazi is offline
3rd Gear
I did the same as h2 autozonw works great $5.00
Old 02-25-2005, 12:45 AM
Terry TK's Avatar
Terry TK
Terry TK is offline
Big Kahuna HDF Member
I have a short black rubber antenna on my roadglide but I don't know where to get one (came on bike). One thing I did see recently that looked really cool was cut off antenna. My dealer's salesman took his stock antenna and cut them off about six inches from top and then put them back in with the stock set screw. Claims the reception is the same. Looks great. Hope this helps!
Old 02-25-2005, 12:56 AM
steveokla's Avatar
steveokla
steveokla is offline
Just have to watch the CB antennas on the Ultras. If you mess with them, you are affecting the reception. Remember that from my ole cb days decades ago...
Old 02-25-2005, 01:24 AM
Pelonz's Avatar
Pelonz
Pelonz is offline
A couple of years ago, I bought mine from Freedom Cycle in Reno, Both for Radio and CB. I have not noticed any loss of reception or communication. The pair cost like $80.00 ,simple screw in installation. The best part about it is no more dealing with antenna's and garage door interference Dont know if the # is still current but here is the one I have 530.865.7010
Old 02-25-2005, 02:53 AM
Blue SOG's Avatar
Blue SOG
Blue SOG is offline
I just replace mine with a generic 12" rubber antenna from Pep Boys. $8.00 and works great. WB also works great. Now I'm thinking I'll experiment with the stock antenna and cut it to 6" as Terry mentioned... I'll let ya know the results when I do it.
Old 02-25-2005, 06:57 PM
investorsc's Avatar
investorsc
investorsc is offline
Homer,
Does the CB work as it did with the factory antenna?
BRUCE
Quick Reply: Shorter Antenna on Electra Glide Classic
