Anyone installed HD LED turn signal lights on their Glide?
I purchased both front and rear HD LED turn signal lights for my Ultra Limited; I got the rears installed with no problems as the lights came with good directions.
But when I started on the front I quickly realized that I need to dismantle the front fearing.
The front lights came with no directions and only said, "see manual for installation".
Has anyone every installed these lights (HD part# 68435-10) or lights like them on their glide? Do I need to take the fearing apart to wire them? I assume I would since the stock wires run up inside there.
You need to get into the headlamp housing, use the original wires to pull an extra length of wire out and use that to pull the new wires back through.
You really should have 99483-## (where ## is the last two digits of the model year of your bike, -11 in your case), that book is a must own...
caleb895
EVO
09-06-2012 09:41 PM
frogbite
16
12-23-2011 08:49 AM
