uh, oh...no horn??
Old 09-22-2010, 11:17 AM
dart451's Avatar
dart451
dart451 is offline
Unhappy uh, oh...no horn??
Hello all,
I have an 01 Roadking and I found my horn hanging from it's wires yesterday. For awhile, I've noticed that the horn operated sporadically...something I was going to get to but didn't! My Bad! Anyway, now the horn won't work...I've disconnected it and tried it under a 12 volt power supply and it honks so the horn is ok. I've gone through my Harley manual and I'm not getting 12 volts with ignition on and horn button depressed. I've bypassed the ground, still nothing. However, when I press the horn button, I get about .06 volts and that's about all which would indicate that the button is working? I have also checked the continuity of the horn wires. When I hook up my leads, I get continuity when I press the button. Anyone out there have a clue what else to check on this beast? I can't see any wires frayed under the tank but then again, you can't see much with the tank on! Thanks
Old 09-22-2010, 11:29 AM
highwayman1224's Avatar
highwayman1224
highwayman1224 is offline
Try one of these. No wires required!
Old 09-22-2010, 12:47 PM
silverbullitt's Avatar
silverbullitt
silverbullitt is offline
Funny. The new Pee Wee Herman Screamin Eagle Black and Chrome Bar and Shield Automatic Horn. Check your owners manual for proper fitment. DANGER, disconnect battery before installation. Death or Serious Injury may result from improper installation.
Old 09-22-2010, 01:24 PM
ZUTEDUFF's Avatar
ZUTEDUFF
ZUTEDUFF is offline
sounds like a bad ground...
Old 09-22-2010, 02:13 PM
SG Mike's Avatar
SG Mike
SG Mike is offline
+1 on the ground
Old 09-22-2010, 02:20 PM
groupw's Avatar
groupw
groupw is offline
...... do you have a part # for that ?
Old 09-22-2010, 02:33 PM
dart451's Avatar
dart451
dart451 is offline
Well, I've checked the ground wire on the horn and it's got continuity to the frame ground. The switch seems good too...it's just lost the 12 volts to it...
Old 09-22-2010, 03:03 PM
SG Mike's Avatar
SG Mike
SG Mike is offline
Take the wire off the switch that leads to the horn and check for continuity. My guess is the switch is bad...
Old 09-22-2010, 05:03 PM
dart451's Avatar
dart451
dart451 is offline
Talking
Ok, it's not the switch and not the ground...it's the fuc*^$@ fuse! Now...I have the official Harley repair manual that was not cheap...and...does it say anything about checking the Accessory fuse in the Trouble shooting section of the Horn? Nope! It sure doesn't. Even if you go to the Fuse section, it doesn't show you that the Horn is part of the Accessories...I guess you have to assume that the horn is an accessory which does make sense but...one would think that it would be part of the Trouble shooting techniques for stupid people like myself! Anyway, that's what it was...the fuse was blown! Had there been something to tell you to check the fuse, that's the first thing I would have looked at!
Old 09-22-2010, 07:39 PM
smithbrl's Avatar
smithbrl
smithbrl is offline
The next time something electrical doesn't, I bet the first thing you do is check fuses. Good lesson, and fairly cheap, although electrical issues can be very frustrating. Glad you found the problem.
Quick Reply: uh, oh...no horn??
