Help! dropped wrench on 6 gal tank - small ding advice
I dropped a wrench on top of my 6-gal fuel tank on my RKC and put a small ding about 3 inches rear of left fuel guage cap. My question is, how does dentless repair work, is it done from the outside or inside, and if from the inside, does anyone know if the large round hole that opens into the tank under the console is open to allow access to get a tool to the dent??
Dent Removal
As long as the paint isn't damaged and its not on a crease paint less dent removal is the way to go. I had it done on the Mrs car a few years ago the dealer damaged the car they footed the bill. I spoke to the guy working on the dent says going price is $100-$175 a dent and they pop em out using tools and get in behind the dent I think he used air compressor too! I asked him about HD tanks and he said he does em all the time amazing when he was finished if you never saw the dent before he removed it you never in a million years would know one had been there!!!! The guy was in the NY NJ area and it was called "Dent Doctors" there are franchises all over the country Dont hesitate go for it, a lot cheaper than a new tank!!
My two cents BV!!
My two cents BV!!
To do any work from inside I recommend draining the tank, removing the sending unit and pump. Center console is easy to remove, just follow instructions in manual-got one don't you? Leave the tank on the bike, but definatly get the stuff out of the way. Teh hardest thing to do is drain all the gas out with out making a big mess. i proped a large funnel under the left tank cross over line, cut the clamp and do like the little dutch boy and plug the near side tank with you finger while the right side drains. then slide 9quickly) a 6 inch piece of 5/16 hose on the left side where yor finger is and drain the left side. Good luck and let us know how the dent removal turns out.
the heat/cold method works too. Best used on a warm/hot day. Wear a pair of gloves, use dry ice and freeze outside dented area. The heat and cold working the metals' molecules make it slowly "pop" out with the help of a hair dryer. Sharp dents require pro dent removal.
Try it ! Its cheap, easy, and only costs a few $$ for the dry ice (which you can purchase at publix groceries, etc. PLUS it doesn't hurt the bike.
