How do I wire into Accessory Switch?
RE: How do I wire into Accessory Switch?
On my 06, there is a harness, prewired under the seat. There is a switched accessory circuit there. Harley makes a splitter harness that you can drive 2 accessories from that port. It is part number 70264-94A. If you are running only one accessory, your dealer will have the plug ends you need to complete your project. ( This info is correct for the 06's, I would think 07 to be the same.)
ORIGINAL: MACK
It would be a waste though to use it for that unless you are certain you wong need it to hook up other electrical items. The normal hookup is simple and straight forward.
Exactly my point. I use two accessories, so I used the splitter. As I mentioned, you would just have the dealer supply you with the single end to put on your GPS wire. I just wanted him to know the splitter was available.
Yes, I would hook it direct too. I put the NAV on the right side and use the lighter for the XM on the left side. I have the XM on all the time and just use the NAV for road trips. I use a RAM mount for both and have been very pleased with the results !
