2010 E Glide Ultra - clicking sound L/H side
Old 09-20-2010 | 07:40 AM
manire's Avatar
manire
Stage II
Default 2010 E Glide Ultra - clicking sound L/H side
Hi I have a Electric Glide Ultra classic. I love the bike, great ride. But I have one problem I have a clicking sound on L/H side of engine forward. I first noticed it at high speeds, 60 to 70 MPH, but now it has become sparatic at various speeds. The dealer said that the HD techs he contacted said it was common for my model and that it could possibly be the transmission or clutch and didn't seem interested in fixing it because the bike ran well. The bike has 1,120 miles and the clicking is driving me nuts. Has anybody else had this problem and what did you do to finally get rid of it.
Thanks
Old 09-27-2010 | 09:48 AM
shortride's Avatar
shortride
Yeap, that about how it usually goes. You have to have a failure before it will be looked into. I agree with that to a degree but sometimes it can get you stranded like it did me.
I had an intermittent starter button switch problem that I could never get to fail while at the dealer. Eventually the starter button failed completely and cause the starter to engage while the engine was running. After having the starter switch replaced, The starter was next to go which cost an extra $65 getting the bike hauled to the dealer with HOG road-side service.
Old 09-27-2010 | 10:29 AM
Scorpion07's Avatar
Scorpion07
Depends on where the clicking is located? Worse case scenario's:
If up at the front of the Primary, it could be your Compensator springs are digging into the cup? Or loose Comp bolt?
If it's in the general Primary area, it could be your Auto tensioner trying to adjust? Or over adjusted?
If it's coming from the rear of the Primary area - Inner Primary Bearing, Clutch Bearing? Or........da da da daaaa, the dreaded Main Gear Bearing?
It could also be something as simple as a loose Fuel Filler Door, or rattling Shifter Linkage?
I replaced my Main Gear Bearing 20K miles later!
Old 09-27-2010 | 10:42 AM
r_ham's Avatar
r_ham
Default Clicking
My 2010 classic does the same thing. I was told it was the adjuster in the primary and it is normal. I have stock pipes and I think that I hear it more.
Old 09-27-2010 | 02:01 PM
easycruzer's Avatar
easycruzer
Mine does the same thing and my dealer told me the same thing. I told them I wanted it in writing that the would not open it up, in case it fails after the warranty ends.
Mine makes a clicking sound and then some days sounds like muffled loose marbles.
wharfcreek
01-14-2019 02:57 PM
chromalox
Shovelhead
03-06-2014 09:28 PM
Just Cause
10-21-2012 02:43 PM
heavyd1951
Shovelhead
01-04-2012 12:41 AM
buchb
05-10-2011 02:40 PM
Quick Reply: 2010 E Glide Ultra - clicking sound L/H side
