pcIII map recommendation
I just picked up my 2006 Sg from the dealer with the new 25 degree injectors. Dealer also did an ecm downlod, so I was wondering if anyone could suggest a good map for the pcIII
2006 sg
s/e air
s/e pro performance slip-ons
stage 1 ecu epgrade
i checked the dyno jet data base , and M807-005 seems closest .
can anyone confirnm if they have used this map?
thanks,
Mike
2006 sg
s/e air
stage 1 ecu epgrade
thanks,
Mike
RE: pcIII map recommendation
Mike ~ I don't think that map is a match for your bike.
The ones that are not prefaced with 05 or 06 are really not the ones you want. I did not see any that said 2006 & certainly not 2006 w/25 degree injectors. Since the 06's have a different (larger) throttle body, different injectors and different code on ECM, these are not gonna exact matches for you. You might find something that will work, but it won't be as good as it could be.
Did you possibly buy your PCIII form FuelMotoUSA? If so, you're in luck... jsut call them & tell'm what ya need. If not... you may end up having to go to a tuner and have one made specifically for you bike.
Hey Phil, I didn't know about FuelMoto when I bought mine. I went strictly by price which sucks. Had I known about FuelMoto, I definitely would have bought from them but the point I am trying to make is that these guy's are great as they have sent me numerous maps to go along with the many pipe changes I have made and I never purchased from them. That says a ton about the company to me. You can bet that any future purchases will definitely come from them. Jamie and FuelMoto are the greatest.
ORIGINAL: bonzo2
What is the web site for those D&D 2 into 1's they look pretty cool. I was looking at Calibur 2 into 1's at Sturgis but couldn't find anyone to install them and then Dyno the bike.
You WON"T be disappointed!!!
Get the P/N and check www.directparts.com for best prices.... Some have used M&M cycles, but I have not. I've heard good things about them too.
jpnelson1978
07-03-2006 08:13 PM
