HD Wind Splitter windshield for Road Glide
Old 09-18-2010 | 03:49 PM
WoodyHD's Avatar
WoodyHD
Default HD Wind Splitter windshield for Road Glide
Bought a Wind Splitter windshiled for my new RG Custom and installed it. Functionally, it works a lot better than the stock shortie, but fitment wise, it seems to suck. There is a gap between the rubber weather strip and the faring in the very front of the bike that varies from 1/16" to 1/8" in places. Also, the adhesive that is in the channel of the weather stripping where the windscreen is placed is not holding the weather stripping in place. I came back from a ride yesterday and found this...
Anyone with the same bike and shield have these problems or is it just me?
Old 09-18-2010 | 05:52 PM
skratch's Avatar
skratch
i didn't use the stock adhesive with my windsplitter. i had a tube of 3m weatherstripping adhesive lying around. have never had any problem with the weatherstripping using that.
as far as the gap in places, i found that if you kept a little pressure on the shield when tightening the well nuts, and do them alternatively (left, then right, working from the middle out), i have no gaps.
Old 09-18-2010 | 06:03 PM
Garcou's Avatar
Garcou
Yep same problems but with cee Bailey windshield, go to any autoglass shop and you can pick up a new molding for 5.00
Old 09-18-2010 | 08:02 PM
WoodyHD's Avatar
WoodyHD
Thanks for the ideas, will try both of your all's suggestions!
Old 09-18-2010 | 10:14 PM
Bfazona's Avatar
Bfazona
I have both the problems you have with your windsplitter shield. I did put a small dab of gorilla glue to hold the weatherstrip in place, but I can not get rid of the gaps. I've tried pressure and alternating how I tighten the screws. I'm def not happy with the fitment.
Old 09-19-2010 | 07:59 AM
notso12's Avatar
notso12
Stage IV
Have any of you have problems with the bike hitting bottom over bumps since the rear end is lower?
Old 09-19-2010 | 08:25 AM
hdnali's Avatar
hdnali
I bought the windsplitter and had the same problem with the gasket. I messed with it a couple of days,got tired of playing with it and took the gasket off the original shield,put the original gasket on the windsplitter,and all is well,no more gasket problems.
Old 09-19-2010 | 08:52 AM
skratch's Avatar
skratch
didn't think of that. maybe thats why i didn't have any issues either. i still have the new gasket sitting on the shelf, reused the original. i just assumed they were the same
not me. and we have some hellacious roads here in la. i need the lower rear so that my feet can reach the ground. as it is, i am not flat footed, but i don't want to go to the 11-1/2 progressives that i had on my roadking. i don't want to compromise the ride. it is much better than the rk was! but, my bike is set up for solo. i never ride 2 up.
Old 09-19-2010 | 09:04 AM
Kim'sOldMan's Avatar
Kim'sOldMan
2nd Gear
I have a 2008 Road Glide that was lowered (1 1/2") and never noticed it bottoming out, even with a passenger and luggage. I don't even scrape floorboards on hairpin turns.
I'd check the air in your shocks?
Old 09-19-2010 | 11:04 AM
Bfazona's Avatar
Bfazona
No bottoming problems here either and I've been on some really rough PA roads already.
bikermikee
Milwaukee Eight (M8)
06-10-2017 07:52 AM
hog-doc
02-25-2010 12:56 AM
Pastor John
12-01-2007 09:32 PM
uweldit
10-17-2007 10:12 AM
Badbagger
03-16-2007 02:28 PM
Quick Reply: HD Wind Splitter windshield for Road Glide
