Can you lug a bike with the rpms at 3000?
Well all I can say is she is bigger than when I first marred her. Let’s just say under 145. I just wanted to cruse and not have to shift. The hills were not very step I try to listen to the engine but the wind drowns the sound of the engine. Highway 395 calif. From Mojave to Topaz Lake it is a long straight high desert highway. The I can fell the engine purring when the road is flat but when I go up hill I fell the engine working harder to maintain the speed. I gust my question is how hard can you push the engine at around 3000 rpms before you screw something up? Will the engine start to buck and stumble?
What you experience in a load to large for the engine speed while turning at High RPMs is in my opinion called "bogging" or "hitting the wall". The engine simply cannot deliver enough power to overcome or maintain the load presently asked of it. So the engine slows and becomes unresponsive to requests for acceleration. If you've ever had a 1983 honda civic you've experienced this. No, it will not hurt the engine unless you let the engine decel all the way down into the low RPMs where it starts jumping around like a rodeo bull and kicking back etc...lugging. Trick here is to down shift.
lp
Accelerating with poor response,... vs downshifting for quicker response is a good example. Lugging.
You're probably right though. My Engineering degree is in basket weaving.
Will not hurt the engine a bit. As long as you have some rpms up and the engine has reached it peak hp, it’s the same as running it on a dyno. I work in the AG Industry where farm engines run at peak power at 1800 rpms all day long. It doesn’t hurt them, accelerate wear or anything else. That is what they are made to do.
