What Spark Plugs you runnin? (other than Harley)
Old 09-19-2010, 02:53 PM
nvsteve's Avatar
nvsteve
nvsteve is offline
Originally Posted by Fl Jimbo 05
Come on!!! there's got to be a better plug out there.
Who indexes their plugs? Does it run any better?
I've got the NGK Iridiums in now and don't notice a bit of difference. Probably last longer but I tend to change plugs before necessary like most of us.
Most I've read is indexing is a waste of time for the tiny potential gain.
  #32
Old 09-19-2010, 05:12 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
There is a very well kept secret that if a guy runs a cooler plug in the rear cylinder and indexes the front plug with the bend of the electrode pointing at the center of the chamber and index the rear plug 180 degrees opposite you will pick up 10% tq at all rpm's. It only works with the Quadruple Unobtainium Flame Thrower spark plugs though and they are hard to come by.
  #33
Old 10-05-2010, 01:46 PM
tpcrawford's Avatar
tpcrawford
tpcrawford is offline
Currently running NGK DCPR8EIX Iridiums. Has anyone tried the NGK DCPR9EIX Iridiums ? They are a heat range cooler than the 8EIX.
  #34
Old 10-05-2010, 02:42 PM
hoethree's Avatar
hoethree
hoethree is offline
HD plugs are made by Champion at the Champion factory near Byesville, Ohio. My sister-in-law sent me a set when they started making them there like five years ago or so.
  #35
Old 10-05-2010, 03:44 PM
nvsteve's Avatar
nvsteve
nvsteve is offline
If you're speaking of the bike in your profile, V Rod, the "8" is the stock equivalent plug, right? The "7" is the cross for a big twin.
I run 1 step colder in my Ultra but not sure there is any advantage. You could try 1 step colder but I doubt you'll notice any difference.
  #36
Old 10-05-2010, 04:04 PM
bdp's Avatar
bdp
bdp is offline
NGK Iridium for me,
Plenty of Utube videos out there showing modest hp gains with a plug change only
http://www.cyclesolutionsonline.com/...park_Plugs.htm
  #37
Old 10-06-2010, 09:49 AM
tpcrawford's Avatar
tpcrawford
My apologies. Yes I have a V-Rod but I also have a 2010 Ultra Limited. I was speaking of the Ultra. Yes, the "7" is the direct replacement for the OEM plug. I'm running the "8" now and have not noticed anything.
-Tim
  #38
Old 10-06-2010, 12:48 PM
nvsteve's Avatar
nvsteve
nvsteve is offline
-Tim
A couple builders have suggested that a step colder is good for builds with higher compression. 10+. As I mentioned earlier I have one step colder on a stock build (stage 1) now and don't think they have any affect good or bad.
2010IRON883
11-27-2011 09:28 AM
CT-Bagger
08-17-2011 11:30 AM
tenrams
Engine Mechanical Topics
02-05-2011 03:40 PM
Fuzzman
03-01-2010 11:59 AM
spankustang
Exhaust System Topics
05-19-2008 04:38 PM
Quick Reply: What Spark Plugs you runnin? (other than Harley)
