What Spark Plugs you runnin? (other than Harley)
Old 09-15-2010, 08:43 PM
Fl Jimbo 05's Avatar
Fl Jimbo 05
Fl Jimbo 05 is offline
Thanks for all the imput. I might try the Autolites. I used to run them in my Evo & Shovel.
Old 09-15-2010, 09:27 PM
Harleyboyddk's Avatar
Harleyboyddk
Harleyboyddk is offline
Denso Iridiums, not because I think they're better than everything else, just don't like running with the herd.
Old 09-15-2010, 11:53 PM
j1mmy's Avatar
j1mmy
j1mmy is offline
i was told autolite makes harleys plugs.. ngk and accel plugs are no good in hd
Old 09-16-2010, 08:23 AM
HKSkully's Avatar
HKSkully
HKSkully is offline
I thought I was wrong on another occasion but I was mistaken, but I believe that Champion spark plug is the manufacturer of the HD plug.
The autolites perform very well indeed but the heat range crossover for the same # in HD has a larger hex than stock size.
I've used the NGK DCPR7E's in my scoots for over 60,000 miles and they have performed excellent and in the other bikes that I put them in, they (the bikes engines) appear to start faster (less revolutions of the starter) than the stock HD plugs that they previously had in them (according to the other bikes owners).
Old 09-16-2010, 08:48 AM
mariner227's Avatar
mariner227
mariner227 is offline
I tried to run NGK plugs in my 07 ultra. I never would have believed it but they caused the check engine light to come on. Code was that rear cylinder was misfiring. Changed back to hd plugs and problem stopped. Resister problem I think.
Old 09-16-2010, 09:46 AM
jmcollison's Avatar
jmcollison
jmcollison is offline
Running Chamions. I found out that the Autolite doesn't fit the plug socket in my road tool kit.
Here's a ? for all of yous...how many of you index the plug when you put them in????
Old 09-16-2010, 10:00 AM
88racing's Avatar
88racing
88racing is offline
Autolites..........
hucks 08's Avatar
hucks 08
hucks 08 is offline
have had no problem with the stock,run stock hd's
Old 09-16-2010, 10:14 AM
H@mbone!'s Avatar
H@mbone!
H@mbone! is offline
I'm using NGK's havn't have not had any problems with them was using Harley Plugs for awhile but NGK's are easier to get a set when needed when the parts store carry them and they are open 7 days a week instead of only 5 plus I have a O'Reillys a few blocks from the house. And they are alot cheaper.
Old 09-16-2010, 10:28 AM
MotorSgt's Avatar
MotorSgt
MotorSgt is offline
I use the autolite myself. I just hate giving any more money to the Stealer.
Quick Reply: What Spark Plugs you runnin? (other than Harley)
