My bike is shocking me !!!
I get a little shock in my right hand when driving under high tension wires some times if my hand is against the inner edge of the grip. Seems to happen when there's three sets next to each other om the expressway. If I move my hand back a little it dosen't happen. It does have TBW.
I must say, some pretty decent input. After I finally got all the way woke up and went to work I realized it most likely would not be straight battery voltage, there would be enough amps to melt stuff, and it would discharge the battery. And on the other side of that coin is the switched voltage, it would most likely blow a fuse.
I also got this shock one time while going under power lines, but was unable to duplicate it. Will be checking the coil and wires this evening, other than that lets ride. My thanks to you all !
My '05 Ultra has been doiong this for the last 2 years. No pattern and maybe months in between. I have hecked everything under the fairing, gas tank, switch housings and battery. Everything is fine, I just get that unexpected shocking from time to time. Funny thing is that it always takes me by surprise and it takes me a minute to remember what's going on. Now, I will pay attention to being around power lines to see if that has any effect on mine.
A carbed Road King would be FLHR.
A fuel injected Road King would be FLHRI.
