Needs torque advice
Old 09-20-2010 | 09:16 PM
coolerman69's Avatar
coolerman69
Originally Posted by arealinvestor
I respectfully disagree.It's not all the same.If you change cams,yes you could loose a few hp,you might gain in tq though.This is why headwork is so important,it can give you more & a better balance of both.The cam,headwork, & compression must be matched to optimize the performance.If at 3,000rpms my bike makes 100hp/100tq & your makes 80hp/80tq is that the same??
Guess i worded that wrong. I was askin if it would change
Old 09-20-2010 | 09:25 PM
coolerman69
You can change gearing,but in my opinion it's a cheap fix.I would want the motor right.As said before you can go down in the front,which is the same as adding to the rear.Do you really want to loose rpms on a motor that doesn't rev much anyway?? The twin cam motor is done making hp/tq at roughly 5,500.That's not much rpm's.Each tooth is probably 200-300 rpms.
I just checked my dyno sheet and realized the tech didn't hit the rev limiter. My motor turns 6700 rpms . It was still on a pretty good climb when he let off the throttle at 6000. I probably need to visit a good tuner
Old 09-20-2010 | 09:45 PM
arealinvestor's Avatar
arealinvestor
Talking
You running it to the redline huh???You know what happens to motors when they redline them??
Old 09-21-2010 | 02:30 PM
coolerman69
Yeah i know redline is the danger zone but me and the rev limiter are real good friends, we see each other quite often. I just cant stay away! I talked to the guy who built my motor and he said it was built capable of turning 7500rpm but limited to 6700 for longevity. It is the quietest motor around. People hear it and cant believe it has 100+ hp until i blow them away.
Old 09-21-2010 | 09:31 PM
dougbk's Avatar
dougbk
Doug i never thought of that. Does that require a belt change?
The same primary chain will work, you will change the compenator sprocket and the clutch basket.
Old 09-24-2010 | 08:00 AM
coolerman69
Thanks Doug i may try that
dutchglide
10-08-2021 09:32 PM
Yo_Boss
Engine Mechanical Topics
22
05-20-2017 10:06 AM
oscarg
04-28-2012 11:13 PM
dontdropit
11-28-2011 09:59 PM
indigofarm
01-16-2011 02:46 PM
Quick Reply: Needs torque advice
