lean tune and poor mileage
Finally got my 06 SG tuned with the help of the Twin Scan+ WEGO IIID. My cruise range AFR is 14.7 and transitions to 13.2 WOT. Riding pretty gently, 1 up, steady highway at 3K rpm or below, 70-75 MPH, I'm only getting 40 MPG. Still 88", stage 1, 2 into 1, PCIII USB. Does this mileage seem out of wack?
I have an 06 sg also,sert,vance n hines slip ons,stage 1 filter. Just had it dyno tuned,hd set afr to 13.8 across the board,running lean before.generally dont run those speeds often,however i'm getting about 45 mpg,tune made a world of diference in readjusting map! Ended up givin me 13 more horses n 10lb torgue
I'm still having a problem with not being a little too aggresive
with the throttle since I put on the V&H exhaust system and PCV. I'm still loving playing with the throttle and listening to the pipes to worry about 3 or 4 mpg. I predict some time in October to be when (it's out of me now) Maybe then I'll pay attention to the mileage. Going to do an Vancouver Island run this week so maybe I'll be tired of the rumbling by then. After that is, I wrangle a rope around our premiers neck and hang him to a lynching from a BCRail locomotive. (lying bastard)
dandrumheller
15
02-19-2019 10:52 AM
