Run Switch vs. Ignition Switch
Old 09-07-2010 | 10:21 PM
geezer glide 56's Avatar
geezer glide 56
I remember when there wasn't a run/stop switch on the handlebar...But that was back when motorcycles had points and carburetors...I still turn the engine off with the key switch...With all of the computers on automobiles I wonder why they don't shut them down with a run/stop switch?
Old 09-07-2010 | 11:01 PM
BLK08ROCKERC's Avatar
BLK08ROCKERC
I use the ignition switch not the kill switch and here is why, the ignition switch is much more robust than the kill switch. I have seen kill switches wear out due to being used so often.
Old 09-08-2010 | 03:09 PM
gaber6's Avatar
gaber6
Hmm probably a pretty good reason. Which one is easier/cheaper to replace down the road, though?
Old 09-08-2010 | 03:17 PM
pit1600's Avatar
pit1600
always use ignition switch. It"s made for and the kill switch is made is case of emergency.
Old 09-15-2012 | 09:30 AM
mgmmgm's Avatar
mgmmgm
Default Insulated gloves
Or....hit N and reach down and pull off your plug wires.
Old 09-15-2012 | 10:17 AM
HDCat's Avatar
HDCat
I knew an old school biker years ago who would leave it in 1st gear and just pop the clutch to kill it. Ha, ha... BTW, on my 08 UC I use the ign to turn off the engine and would use the handlebar mounted "kill switch" for an emergency.
Old 09-15-2012 | 10:19 AM
hattitude's Avatar
hattitude
That will void your warranty.......
Old 09-15-2012 | 10:39 AM
WARDSPARTSWERKS's Avatar
WARDSPARTSWERKS
And possibly void your bowell
Old 09-15-2012 | 10:42 AM
PosterPerfectPhoto's Avatar
PosterPerfectPhoto
Maybe, but it would be a real kick in the azz.
Old 09-15-2012 | 11:03 AM
blarg's Avatar
blarg
Run stop run stop ign off ign off acc ign acc ign left turn signal right turn signal both turn signals shifr into second gear and honk the horn twice.
It unlocks the unlimited gas cheat codes on all Harleys.
Quick Reply: Run Switch vs. Ignition Switch
