"lugging"
Old 07-18-2011, 07:21 PM
shooter5074's Avatar
shooter5074
shooter5074 is offline
Location: Western Illinois, land of bad roads, and corrupt politicians
This thread is proof positive that you should not believe what you read on the internet.
  #72
Old 07-18-2011, 08:07 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
if you have no idea....shift with speed...leave 1st by 20, leave 2nd by 30, leave 3rd by 40, etc.
lugging is about not down shifting an a manner that results your rpm to drop to the point the engine becomes unstable and your putting stress on your bearings and crank.
  #73
Old 07-18-2011, 08:32 PM
MNPGRider's Avatar
MNPGRider
MNPGRider is offline
Originally Posted by Silverback2011
I would have never considered a green Harley as my first two were black but once I saw it in the showroom I had to go green.
According to my 2011 manual the 6th gear drive ratio is 2.875, is that different than your 2008?
I just found the upshifting gear speeds in my manual and it says fifth to sixth at 55mph or 85 kph, that seems awful low to me.
Tthe 2008 is 2.790 in sixth.
The purpose of a transmission is to match the road speed with the engine speed. Check any torque table, and ride accordingly. The Twin Cam engines make maximum torque at 3500 rpm.
  #74
Old 07-18-2011, 09:55 PM
checkers's Avatar
checkers
checkers is offline
Originally Posted by JCleary
If I'm rolling down a flat road at 25-30, I'll run in 3rd gear which is 2000 or less. Never would I try to accelerate in third from that speed. I always drop a gear. If I've got any load on the motor at all I'm keeping it over 2500.
X2, good advice.
  #75
Old 07-18-2011, 10:44 PM
LastHalf's Avatar
LastHalf
LastHalf is offline
I can only imagine how good that looks in person vs in the picture, and from different angles. My next Harley will be that exact shade.....you sir are a man of impeccable taste!
  #76
Old 07-18-2011, 10:57 PM
iclick's Avatar
iclick
iclick is offline
I understand "lugging" to be like several have described here, which is when the engine struggles to accelerate by shaking or jerking. I go by feel and usually keep my bike above 2k RPM in 1st thru 5th gears, and 2100 or so in 6th. My old Evo RK could run all day in 5th gear at 1800 rpm without any hint of lugging.
  #77
Old 07-19-2011, 05:36 AM
LastHalf's Avatar
LastHalf
LastHalf is offline
Nice looking bike - how do you like those SE255 cams (thinking of getting them with the Stage II kit), is your engine a 96 or up to a 103, and do you have pinging issues? I heard that can be a problem, but they you have some controller that I presume adjusts fuel and timing.
Anyway I`ve been told 2100 rpm is too low and my broken piston were kind of carboned up over by the fracture so I`m wondering if lugging led to carboning up which led to hot spots which led to.....looking for SE255 cams to go with my 103 big bore since mechanics were elbow deep in my engine anyway replacing one 96 ci piston and cylinder!
  #78
Old 07-19-2011, 06:06 AM
Route66rider's Avatar
Route66rider
Route66rider is offline
Throwing in my two cents worth here, but at any speed I never let the rpm drop to the point that I can not get out of a bad spot by just twisting the throttle. If I see something that I need to avoid in a hurry I do not want to be in the position that I will need to waste any amount of time by needing to downshift before I can speed out of the way.....
  #79
Old 07-19-2011, 05:53 PM
AlCherry's Avatar
AlCherry
AlCherry is offline
Shhhhhhhhhh, I'm almost a road captain!
  #80
Old 08-03-2011, 02:59 PM
klaybus's Avatar
klaybus
klaybus is offline
General rule of thumb for me is to cruise around 2000+ for rpms. I have never had any pinging riding like this personally but it sounds like it is a problem for some. (pinging) I guess maybe I too will increase my use of 5th gear or perhaps cruise at higher speeds....
Quick Reply: "lugging"
