I need help with part nubmers please...
I need the part numbers for the following parts for 2002-2005 baggers as I am putting a kit together to go with Ricor's intimnators. If anyone (Dawg) or anyone else happens to have these handy that would be extremely helpful. Yes, I ride a softail so I am nearly clueless about this stuff for baggers as of yet.
1. Stantion
2. Damper rod, or called a down tube
3. The oil lock at the bottom of the damper rod
4. Damper rod wear band if it does not come with the damper rod
5. Screw and copper washer that holds the damper rod.
6. The 1” top out spring
7. All the bushings and seals
8. Fork springs, it may be better to get another brand for the fork springs. I’ve had bad luck with the progressive brand springs not sure if you have others to choose from or not.
Thanks!
Drew
1. Stantion
Thanks!
Drew
