Hi,
Has any one installed a SE heavy breather kit or anything along the same line on a touring bike with lowers?
They say it will not fit in the instructions so just wondering if someone had tried do it.
Thanks Thistle
Yes, I've seen them on several bikes with lowers. They clear the lowers glove box flap by about 1/16". Not sure if it's the HD one's or aftermarket, check your JP cycles catalog as well.
Thanks everyone for your replies. Gambler, how much clearance does that short filter give you? I have the Hog Tunes lower speaker kit installed so I think I'm screwed . Thistle
Yea...you're screwed! You can barely get a finger in between the end of the filter and glove box cover! If the speaker setup you have sticks out almost any at all, it will not fit.
