My Fat Cat baffle review.
yeah you can only tell the difference by looking inside at the baffle, the concentric is the quiet, the wrapped louvered (standard) is the performance, the plain or unwrapped louvered is performance also but described as being obnoxiously loud by D&D, then if you have a big bore build you should go with the borezilla
Concentric baffle= it has a cone down the middle of it. You can't see straight thru it. Very quiet and no performance to speak of.
Quiet baffle= wrapped baffle. You can see straight thru it. Deep rumble. Not that loud. When holding it in your hand the outside of it is wrapped in a cloth like substance.
Performance baffle= You can see straight thru it. When holding it in your hand the outer shell is metal. It isn't that loud.
![Big Grin](https://www.hdforums.com/forum/images/smilies/biggrin.gif)
what you are calling the quiet baffle is what im referring to as the standard. the concentric(quiet) had the cone inside, the other two have louvers inside, the one that is 15% quieter(standard)is wrapped perforated(you cant see this wrapping unless you take the baffle out) the wrapping make it 15% quieter than the loud obnoxtious one which is also louvered on the inside. you can take the baffle out of the standard remove the wrapping and it will become louder. you are right i have heard louder but not louder and still retain that deep rumble
