Sg "bullet" turn signals on an EGC?
Old 09-06-2010 | 12:21 PM
JoshuaCannon's Avatar
JoshuaCannon
Default Sg "bullet" turn signals on an EGC?
Are they compatible. I have the passing lamps and the large style turn signals but I would love to have the smaller bullet style signals front and back. Will they mount to the same mounts? Can I just swap them ?
Old 09-06-2010 | 12:43 PM
Harleypingman's Avatar
Harleypingman
Nope; not compatible using the OEM turn signal bar in the rear, or the towel rack light bar in the front. If you go to HD's website and look at the bullet turn signal kits for the EG, you'll see they mount differently than the SG bullets.
Carl
Old 09-06-2010 | 01:59 PM
bmcgc's Avatar
bmcgc
I guessing the rear lightbar will bolt on, I think there is one on ebay now.. On the front you would have to get the SG turnsignal mounts to run just the signals, the entire SG light kit to keep the passing lamps.
Old 09-06-2010 | 04:00 PM
'05Train's Avatar
'05Train
The rear signals bolt and wire right up. The fronts won't work. The MoCo sells the CVO-style passing lamps and bullet signals as two separate kits. It's about a 2 hour install.
Old 09-06-2010 | 04:56 PM
jimsuver's Avatar
jimsuver
69147-03,80153-03 or 69063-03 any of those numbers will get you close to the SG look. I only used the front of the kit and a used rear SG bar and plane amber lenes. Its a good look for 129.95 I think.
Old 09-06-2010 | 04:58 PM
jimsuver's Avatar
jimsuver
That 2nd number should be 69153-03
Old 09-06-2010 | 07:21 PM
JoshuaCannon
That is exactly what I needed.. Thanks guys! Not a bad deal for all 4
Old 09-06-2010 | 08:00 PM
Garemlin's Avatar
Garemlin
I had bullets on my 09 EGC.
Front
Rear
I used the rear bullet bar conversion kit 68615-04 for the rear. For the front I got the parts breakdown for the Bullet Style Turn Signal Kit and just ordered the front bullet lights. The part numbers are
69165-03 (amber lenses)
69201-03 (clear lenses)
69203-03 (smoke lenses)
You may want to order the socket housings (plugs) just in case yours are different. I know mine were. Part numbers are 73156-96BK.
For the fronts make sure you order two each of the signals and socket housings.
JONESER900RR
10-23-2017 09:59 AM
youngrider
07-27-2010 03:57 PM
Arvid
11-12-2009 12:19 AM
Bobberino
02-18-2008 09:55 PM
shark
01-30-2008 03:20 PM
Quick Reply: Sg "bullet" turn signals on an EGC?
