Fair Price to Change Fork Oil?
Old 09-08-2010 | 06:03 PM
iclick's Avatar
iclick
Originally Posted by watercop
My question is, is the drain on the bottpm of the fork the phillips head screw on the back side or the screw going up from the bottom?
It's the Phillips-head screw, and use a ratchet and bit rather than a screwdriver, as it will likely be very hard to get out the first time.
...and by "pump the forks" as the oil is added, are you suggesting to just push on the handlebars with the weight of the bike on the ground....
Yes, but since you have an RK without a damper in the forks you may not need to do the pumping routine. I would still add a little at a time, pumping a few strokes in between.
Old 04-12-2011 | 01:04 PM
Gliden's Avatar
Gliden
I just got quoted today 4 hours for my bike to change the fork oil from stock oil to S.E. oil.
4 hours.......
Old 04-12-2011 | 01:26 PM
iclick's Avatar
iclick
4 hours.......
They are probably following the service manual for a complete fork disassembly. I think this might be advisable at 50k miles, if for no other reason than to inspect the bushings, but before that I see no reason to do it, and a simple one-hour oil change as per my write-up is a good idea.
I just did this for the second time (22k miles for the first, 44k recently), and the oil looked just as black and opaque as it did for the first change. I didn't have this with my old RK with air-shocks, but I changed the oil every 10k in that bike and the oil usually looked very clean.
Old 04-12-2011 | 01:29 PM
texaswiz's Avatar
texaswiz
All Harley dealers use the MOCO flat rate book to charge for every procedure. My experience is that the procedures that dealers use to fix most anything are excessive in most cases. They want to pull the forks off to change oil, for instance. If you can walk, chew gum and read a shop manual, do it yourself. A shop manual is usually about $50.00 or so from the dealer. You will pay for the price of the manual on your first oil change you do yourself.
Old 04-12-2011 | 03:13 PM
Gliden's Avatar
Gliden
Thanks Guys. I do as much as I can but I really don't even care to play with the forks. (Now that you mentioned it) I heard him say the word "disassembly".
I only have 15K on this bike. I typically lean to the side of over doing things but if you think it's a complete waste to disassemble at 15K let me know and I'll just have them "Change the fluid" .....I appreciate the feedback and the tip that they are disassembling.
Old 04-12-2011 | 03:16 PM
bmaier's Avatar
bmaier
Originally Posted by iclick
DIY for the price of the oil, and you don't need to "play with the forks."
The write-up is here. Scroll down to Post #23.
Piece of cake, on a batwing less than an hour
Old 08-16-2018 | 12:27 AM
Justin Frisk's Avatar
Justin Frisk
Stage I
Default Wheres your shop..............
Originally Posted by Jday53
I run my own shop and I charge $50 for a fluid change thats the fluid and labor
Where are you located
Old 08-16-2018 | 08:11 AM
Veekness's Avatar
Veekness
I would say that after eight years, folks have probably moved on. You might try a private message, in the event that they might still be participating in this forum.
Old 08-16-2018 | 08:26 AM
F150HD's Avatar
F150HD
Old thread I know but....
Jims has some kind of reverse fork bleeder tool, saw it in their catalogue PDF online while browsing.
jimbo285
EVO
05-07-2014 11:09 AM
rooti
06-25-2012 06:01 PM
samabb1
02-06-2012 08:00 PM
CKS
09-28-2010 01:41 AM
Uncle Scrooge
09-04-2009 05:30 PM
Quick Reply: Fair Price to Change Fork Oil?
