Fair Price to Change Fork Oil?
Old 09-06-2010 | 06:58 AM
smokindave's Avatar
smokindave
About an hour job, pretty easy. Got a shop manual?
Old 09-06-2010 | 07:02 AM
Notgrownup's Avatar
Notgrownup
I did it twice now with the write up that Iclick has....and it's a lot harder with a electraglide.
Old 09-07-2010 | 05:54 AM
watercop's Avatar
watercop
The click "here" link does not work on Iclick's post. Would be interested in reading this if anyone else knows where its at.
Thanks
Old 09-07-2010 | 05:29 PM
iclick's Avatar
iclick
Thanks
Yeah, I copied the link wrong. It should work now.
Old 09-07-2010 | 06:47 PM
maineultraclassic's Avatar
maineultraclassic
Originally Posted by Jday53
I run my own shop
Where?
Steve
Old 09-07-2010 | 07:16 PM
street_glider's Avatar
street_glider
This is a practical DYI, with good results.
Old 09-07-2010 | 07:48 PM
watercop's Avatar
watercop
Thanks Iclick, I read the other thread in its entirety. Gotta be careful when someone goes outside the manual recomendations. Youre explanation was straight forward, plenty detailed, and plenty of good discussion and feedback. I'm going to give it a try. I had new lower chrome forks done about 7500 miles ago, and assume the dealer put fresh oil in...but who knows.
Old 09-07-2010 | 08:30 PM
nemick's Avatar
nemick
Just don't freak out if the old oil is a nasty, smelly black goo. The stock oil is some weird stuff. I used HD Heavy on my '09. Worked great.
Old 09-08-2010 | 05:15 PM
watercop's Avatar
watercop
One last question and I'll let you guys go on to more important stuff. Manual says 11.1 oz a side for the the road king, 10.6 for all others. On my RKC, looks like I just remove the nacelle..no big deal there. My question is, is the drain on the bottpm of the fork the phillips head screw on the back side or the screw going up from the bottom? and by "pump the forks" as the oil is added, are you suggesting to just push on the handlebars with the weight of the bike on the ground or perhaps use my lift and and lower the weight of the bike up and down with the lift?
Thanks much for all the fine help
Old 09-08-2010 | 05:30 PM
street_glider
THe drain is up on the side - not the bottom bolt.
I gently - and I mean gently (don't ask how I know) pushed the front end down - basically collapsing the forks. I think this helps move the oil deeper into the fork and provides the room to get all the oil in.
I did it without the vacuum pump - but I bought one to do the rear shocks - OH, Yeah the rears will need some attention too! The rears are a bigger improvement, at least it felt that way with my big ****. Search for those threads or check here>
https://www.hdforums.com/forum/touri...ifference.html
or
https://www.hdforums.com/forum/touri...ansfusion.html
I think if I were to do the fronts again - I would use the vacuum pump to keep it clean and easy.
Autozone has a really well made system for like $30 - Good Luck, and enjoy the new ride (it will feel like a new one).
Quick Reply: Fair Price to Change Fork Oil?
