Gas or Gasohol?
It doesn't matter if it's 5% or 20% (potato/po-taw-to). Even if it's only 5% you're still using 5% more fuel to go the same distance which makes your vehicle 5% less efficient. Not to mention the horrible side effects to your fuel system and the added cost not only for maintenance but for the ethanol itself.
Your vehicle will emit exactly the same amount of emissions on straight gas as it will with a 10% ethanol blend.
And there are no "horrible side effects" to any fuel system made after 1985 (give or take). Yes, older engines with older rubber have had issues. After fuel lines and seals were replaced, things are fine. Remember when leaded fuel was phased out? Old engines had horrible problems with valve seats. Manufacturers adapted and we all run unleaded fuel now.
Alcohol is a great cleaner and by that logic keeps the fuel system clean. I have no added maintenance costs associated with E10. If you refer to the cost of fuel stabilizer for long storage periods, that is necessary with straight gas too.
If you want to hate ethanol, fine with me. At least do it for some real reasons like increased corn prices, pork barrel legislation, whatever. The "it will kill your engine" argument has been debunked many times over as evidenced by the millions of engines that have been using ethanol blended fuel for years with no ill effects.
Make no mistake though, I'm talking strictly about E10. E85 is a different animal all together.
E10 will and has routinley run gaskets dry rotted. Not on my bike, but as someone who has been a gas tanker driver for a decade can tell you. The hose end o rings and dry brake valve rings dry rotted on all our trailers back in 2006 when the gas became E10.
Of course our vendor then supplied us with rings that are beefier for that reason, maybe, just maybe the MoCo thought that far ahead too?
Just saying...
Just saying...
But if I'm using 5% more fuel, it contains 10% less fossil fuels. The point ethanol advocates make is that emissions are supposedly different than the fossil fuels. I'm no chemist, just throwing it out there.
I don't like not having a choice when it comes to ethanol. In my state and all of the surrounding states gasoline without ethanol isn't available. Every vehicle I own runs better (read more efficient here) on straight gasoline - especially my bikes. Yours does too, you just don't know it.
No offense man, but you've swallowed the ethanol argument hook, line, and sinker. I can't say it any plainer: you're using more fuel to go the same distance when ethanol is added to your gasoline. Since your vehicle is now less efficient you are now using MORE fossil fuel, not less.
Now, I never said it didn't run more efficiently on straight gas. I'm not an ethanol proponent at all. What I'm trying to explain is that if you use 5% more fuel on an E10 blend, you have used less fossil fuels than you would have on straight gas.
For example, lets say you go X miles on 1 gallon of straight gas. At the 5% argument (40MPG down to 38MPG), it takes 1.05 gallons of E10. But that 1.05 gallons of E10 is only 90% fossil. That means you've only burned .95 gallons of fossil fuel (straight gas) and .1 gallons of ethanol. That's all. Simple math. If your economy fell off by 20% as you indicate (lets say 40MPG down to 32MPG), that same distance of X would require 1.25 gallons of which 1.13 gallons is fossil fuel (again, straight gas). So yes, if you lose 20% of your MPG, you do burn more fossil fuels.
I work in oil and gas, so I am well aware of BTU factors and the energy contained in various oil and gas products and the relative efficiencies of them.
I know you have your mind made up, and it's good to see you dropped the whole "destroying the engine" argument in favor of the "costs me more in the long run" argument. That's a valid reason to not like ethanol. Well done.
Oh, and I totally agree with you on the not having a choice thing. I'd rather run straight gas, but the truth is that sooner or later (probably not in our lifetimes) we will have no choice but to come up with something else to get us from A to B. Just the way a finite resource is.
I was talking to my brother who is a well trained GM Technician, yesterday. In our conversation, he mentioned that the Gasohol made a rather large drop in fuel mileage in cars. Out here in Hawaii we have no choice. You get alcohol with your gas. My question is this, when doing long distance riding do you all see the difference in mileage buy using these different fuels? Is is worth it to have alcohol in your gas?
Discovered this years ago when they first started shoving that stuff down our throats in Iowa.
