Gas or Gasohol?
Sorry for the double post, My fat fingers must have hit "Send". I have been on the road for a working vacation in Montana. It drives me nuts that I cannot bring my bike to the mainland for every trip. This is a fantastic place to be riding. Thanks for the input on the mileage, I might have to try a tank of Boat Gas (no alcohol) to see what my mileage actually does. I do use the highest octane, but all of our pump gas has some alcohol. Thanks again guys!
Using any gasoline with 10% ethanol reduces fuel mileage as much as 20%. A fact that is inarguable. Do the math. If you're getting 20% less fuel mileage you're buying 20% more fuel. I'll repeat that: you're buying more fuel to go the same distance. How can that possibly be cleaner (as all of the ethanol advocates claim)?
It doesn't matter if it's 5% or 20% (potato/po-taw-to). Even if it's only 5% you're still using 5% more fuel to go the same distance which makes your vehicle 5% less efficient. Not to mention the horrible side effects to your fuel system and the added cost not only for maintenance but for the ethanol itself.
Your vehicle will emit exactly the same amount of emissions on straight gas as it will with a 10% ethanol blend.
