View Poll Results: Do You Use A Torque Wrench
Always On All Fasteners
57
30.00%
Only On What I Think Are Critical Fasteners
119
62.63%
Waste Of Time I Just Snug Them Up
5.26%
What Is A Torque Wrench
2.11%
Voters: 190. You may not vote on this poll
Do You Use A Torque Wrench?
I consider most fasteners critical so I usually, use one. If I'm working on something without a manual then I go by industry standard torque specs for that size and grade of fastener and that type of materials involved. Use a torque wrench I still have some idea about how tight a fastener needs to be and what that feels like (because of experience with torque wrenches).
I've seen several guys who never used a torque wrench be surprised when they start using a torque wrench. Usually they find out they were over torquing the small stuff and under torquing the big ones.
Received 5,424 Likes
Yes, always if torque is quoted in the manual. I have a foot-pound and inch-pound wrench. Be careful which one they are quoting in the manual. Years ago the mounting bolt for the front motor mount on my 97 Wide Glide stripped when I was changing out the mount. I had tightened it to the torque per the manual. Went back to dealership, they grieved it to the factory using the torque I stated I used. It took two months, but I was reimbursed for the part, which was about $140 at the time. Lesson learned.
Im happy to see the majority is Yes! I always do and have a chart for standard torque values and other to show variances for Dry Threads, Oiled Threads, Extensions etc, In case i dont have a Manual.
A comment was made in one of my other threads that made me wonder.
I recomend everybody buy them. Sears sells both Inch and Foot ones for pretty cheap and work fine. Don't forget to set them back to Zero when not in use.
