Duals and Slip-Ons with NO Fuel Manager??
I have an 08 that is all stock and found a set of used 4" Cobra Slip-Ons and installed them last night. Great sound out of the right pipe but would be a lot better if that same sound was coming from both pipes. So now I would like to add true dual head pipes and nothing else at this time. I have always heard that you can change slip-ons or A/C without adding a fuel manager but if you do both you will need to add one. I would like to just add a set of true duals and see how the bike does from there with just the slip-ons and truel dual headers. I was suprised that the bike seems to run a little smoother and better throttle response with just the slip-ons. The heat does not really bother me now and I love getting almost 300 miles per tank so if I do not need a fuel manager with just adding slip-ons and dual headers that would be good. Later if I want to add a little more I will get the PCV and A/C from Fuel Moto.
Thanks for the help.
I'm Sure Others will chime in with their feedback. I go by the rule that if you did not increase the fuel/Air Intake you should be fine. However to take full advantage of your setup and maximize performance I would recomment you get a PC.
Your motor is exhaling a lot better now, and because the motor is able to exhale a lot better, that means it can take more air/fuel mix in. (Which means more power). and for that you will need a better air intake and a fuel mangenment system. Or $400 at the stealer for a stage 1 download.
Just my 2 cents, I'm sure you will get more feedback shortly and will be able to make your decision.
Good luck
Good luck
When I added my PCV from Fuel Moto my mileage dropped about 3 to 5 miles per gallon. Jamie can get you a map for better fuel mileage. You can either switch maps on the fly or use your laptop and load your new map. Your bike will run better with PCV, not necessarily faster but more responsive and cooler. I noticed the difference in heat (right thigh and calf) right away. I don't have an oil temp gauge so I don't know how many degrees but it is cooler.
StreetGlider57
12-21-2008 01:06 PM
