Rear tire wining , driving me nuts????
Old 08-31-2010, 06:45 AM
Sibs's Avatar
Sibs
Sibs is offline
Default Rear tire wining , driving me nuts????
On my 02 Classic I'm getting a bad tire wine.Sounds like something rubbing but its all clear and strait.
The tire starts to make a enoing wine at 60 MPH .No vibration I can tell.
Tire is a Harley Davidson Dunlop D402 MT90B16 M/C 74H.
Any ideas would be much apreciated.
Thanks Sibs
Old 08-31-2010, 06:51 AM
Notgrownup's Avatar
Notgrownup
Notgrownup is offline
Received 7,124 Likes on 3,660 Posts
Is you belt properly tightened and wheel lined up? Just hasking hey. I did have a 402 that whined a bit after a while when it started cupping...
Old 08-31-2010, 06:53 AM
Motorboatn SOB's Avatar
Motorboatn SOB
Motorboatn SOB is offline
Check your tire pressue. Rear tires will wine if the pressure gets low enough.
Old 08-31-2010, 07:10 AM
Sibs's Avatar
Sibs
Sibs is offline
What do you mean by cupping? Flatteing out?
Old 08-31-2010, 07:26 AM
upstate tim's Avatar
upstate tim
upstate tim is offline
Rub your hand down the face of the tire and see if you feel high/low spots.
Would feel wavey if cupped.
Old 08-31-2010, 07:32 AM
Sibs's Avatar
Sibs
Sibs is offline
Will do Thanks
Sibs
Old 08-31-2010, 01:56 PM
Notgrownup's Avatar
Notgrownup
Uneven side tread wear.
Old 08-31-2010, 01:59 PM
Turbo Turtle's Avatar
Turbo Turtle
Turbo Turtle is offline
It's just a guess, but I'd say it was the drive belt tension. That's an easy one to check.
Old 08-31-2010, 02:26 PM
Sibs's Avatar
Sibs
Sibs is offline
Tire pressure was down around 25 LBS in the back so I upped it to 40 as per manual.
Still wining so I would agree that its the belt. I pulled the clutch in on the hiway several times and it really seems to be the belt.
I have a service manual ordered for this bike. All I have are softail manuals.
Anyone give me a quick how to on adjusting this belt.
I just picked the bike up a feew weeks ago.
Ive been out of the loop for 7 year recooping from a bad accident so my memory also sucks right now.
Although I use to build all my own bikes I have lost so much, and I have alot to learn about the twin cams Especially this Classic
Thanks Al
Old 08-31-2010, 03:24 PM
BBStacker's Avatar
BBStacker
BBStacker is offline
Pulling in your clutch isn't gonna keep the belt from moving. All it's gonna do is disengage the clutch.
Now, did you notice the "whining" stopped after you put 16 more lbs of air pressure in the tire prior to playing with the clutch?
I would think if the belt is out of adjustment it would start making noise prior to 60 mph. JMHO.
Check to make sure your tire is aligned properly too. Hopefully it isn't rubbing against anything. Check the sidewall for signs of rubbing.
Quick Reply: Rear tire wining , driving me nuts????
