looking for help/info in installing a tach on my 03 roadking , looking for the pink wire under the tank console it is supposed to be in cavity 3 but there is a green/white wire in that spot .should i connect to that wire of rip everything apart to find the pink wire. thanks
the pink wire is in there. if you haven't taken off your tank go ahead and do that then get into the wiring harness. you'll find it in there. On my bike it made a loop up one side and back down the other side.
