Changed shock oil today.Pics.
I recently changed the oil in my shocks and forks. I went with Amsoil 10 wt shock Therapy in the rear shocks. Great improvement. Riding solo, I run about 5 psi. Don't really need any riding solo, but for dampening purposes I put 5 PSI in. Lot of misinformation about the Showa Shocks on touring bikes. They are better shocks than people give them credit.
I used SE fork oil in the forks. helped a lot with the front end dive when stopping.
mrbreezeett1 (02-28-2020)
From appearance you would think the front forks are wearing out much more than the rear shocks, the rear shock oil comes out looking almost new while the front fork oil looks pretty contaminated, I would expect the rear shocks to go 100k easy
I changed the fork oil at 40000 miles,that oil was very black.I think the forks take more of a beating.
If you do the job, please make a note of how much oil is required and do a follow-up on this thread or PM me. I also have some stock 12" SG shocks (not on the bike) and need to replace the oil since some has drained out. I'd like to sell them but can't until the oil is put back to the correct level.
Yep it's all true. I read and read and read......
I did the same just awhile back and have now run 450 miles since changing the fork oil and shock oil - - Yes it makes a hudge difference. I am using Amsoil Shock Therapy #10in my 13" OEM shocks, (it is ten weight, OEM shock oil is five weight).
I initially changed my fork oil to the same but have since went to DAWG's 50/50 mix using - - HD Type E Fork Oil (10 weight) & SE Heavy Fork Oil (15 weight) which means I am running a 12.5 weight oil in the forks and it is about as good as you can make the OEM forks feel. I like-um. The Amsoil #10 felt pretty good, just not quite as firm as I needed for high speed sweepers - still felt a bit soft. With the 50\50 mix it is really good - soft enough for me to feel my a cushy ride yet no diving, even when I lock the front up.
My FLHX with the newly installed Progressive touring link, and shock/fork oil changes feels great. I have speed tested the bike since and the changes are significant.
Also, as a note: I adjusted the sag on my OEM shocks as prescribed by texasbowhunter.
He wrote a post - "How TO Make Your Stock Shocks Better" - A very good read..
While the shocks are mounted on your bike, slowly bleed all of the air out of your shocks, disconnect the air hoses, screw a 1/8" fitting with a hose attached to each shock independently - make sure each of the hoses are in a separate drain pain/measuring cup, now sit on your bike and you will burp out a few ounces of fluid - he explains this is your sag adjustment. Re-attach all air lines and aid air back to your shocks.....next go take a smooth ride for the first time.
Oh, what a felling to have the bike feel just right for you,,,I mean me. lol
Good luck, and good reading.
![Smile](https://www.hdforums.com/forum/images/smilies/smile.gif)
