Changed shock oil today.Pics.
I have replaced the oil in 2 different sets of shocks. I also went with the 10wt Amsoil Shock Therapy and I have been very pleased with the results. The first set I changed was a lowered shock set that had been installed by a HD dealer for the original owner. When I drained them the right shock had 2 oz less oil than the left. After I changed to the 10wt I no longer bottomed out all the time
Neat design!
Over time the shock internals wear out. Oil changes wont help. Shocks should be replaced.
I went with Progressive 416 shocks on my 08 Ultra SE3 What a smooth ride !! Major difference in handling, no bottoming out when I finally got the correct amount of air in them.
http://www.progressivesuspension.com...ies/index.html
it's your bike and you can do what you want but replacing air shock oil is not a recommended service and completely unnecessary.
my service manual says:
Never lay the shock down as this can cause a loss of oil thru the compression fitting if the air line is removed.
any loss of oil requires replacement of the shock absorber. Air shocks are not repairable. Replace the shocks if damaged, worn or any sign of leakage is observed.
![Icon Screwy](https://www.hdforums.com/forum/images/smilies/icon_screwy.gif)
Another HD Dealer BS brainwashed sucker.
Steve
At this point,the shocks are not worn out.
I only did it thinking the fluid should be changed and may improve the ride quality like others said.
How long should these Showa shocks last anyway?
Screamin eagle parts are only made for racing...........right?
Because that's what the book says.
Sorry, but if I did or didn't do everything I read or heard from the motor company I'd be on a fully stock or way way way over paid for bike only serviced by a dealer.
Truth is their full of sht. They are governed by Insurance companies, lawyers, and sales departments and looking out for "THEIR" best interests NOT YOURS.
As they should be I guess, its a business.
But as far as shocks (lets pull it back on topic) I've done this on new bikes and it works really well. A heavier wight oil just felt better to me.
But if you do have the cash I recommend upgrading to Progressives. I've been riding 440's on several bikes for a long time. I've used 412's and 418's. I like the 440's best but the others are still better then the stock air shocks IMHO.
Good post by the way, thanks
Made this simple press for changing the shock oil today.
I used part of a HighLift jack held in a vise and drilled a couple of 1/2" holes for bolts in a piece of wood.
I removed the air line fitting ,mounted it up side down and pumped the 50000 mile oil out.Measured the oil out of one shock and it was at 10oz.
After draining mounted the shock upright with a fitting,hose and funnel.Had my helper(wifey)hold the funnel and pour the new fluid while I pumped the shock to purge the air and let the oil drain in.Worked pretty good.
Will follow up with the ride results.
I ride an 03 EGC...I bought a set of 06 SG shocks (chrome) off Fleabay. When I got them, the airline holes had plugs in them but there was a fair amount of oil in the box. When I put them on the bike, man !, they sucked ! Bottomed out over any little bump. I took them off and drained what oil was in them out....only about an oz in each. I read in a thread here that the oil from the factory is 5#....I purchased 7# and added 10 oz to each shock....what a difference ! I recommend playing with your shock oil wt and also amount until you can find your best ride. The stealer will always want you to buy new from them. Now, if anyone has a good place to buy replacement air lines, I'd like to know...thanks,
![Icon Patriot](https://www.hdforums.com/forum/images/smilies/icon_patriot.gif)
I needed longer lines for my Dyna to relocate the filler and yep - you can get it from the dealer. Part number is 54354-94A - comes in a 25 foot roll for about $16 I think.
