Tire Pressure Monitor
My 2008 Street Glide has its stock wheels with the rubber valve sticking out at a 45 degree angle. The TireGard TPM has these air caps that house the electronics that monitor the pressure. It appears that the front wheel's valve and "new" cap will be OK, but I am not sure about the rear wheel. Has anyone had experience with this system? Do I need to spend more dollars to have a new wheel with a 90 degree valve stem for the tiregard gizmo to work without breaking it on a brake caliper the first time I ride out after the easy install.
I've been running the Tiregard tire pressure system for nine months now on my 2010 Ultra Limited with the stock mag wheels and valve stems. On your bike I'd suggest that you check the clearance to the brake calipers as the wheel rotates. It's a good system, it warns you with a beeping sound and it vibrates if your tires start loosing pressure or getting too hot with adjustable set points. I set the alarm set point at 2 psi lower that I put in to the tires. I've had no problems with the Tiregard system.
