Wild 1 518 install question
Installing these on 07 RKC, my plan was to install "normal" mode and go back later to run the wires through the bars. (winter....yes we get some cold weather in January LOL)
Has anyone run with the wires in the standard or outside of the bars on 518 install? It seems since there is no dimple, only the hole, so I may have no choice but to go ahead and run the wires internally?
I installed 508's on my 08 RKC with extensions and hated dealing with the duestch (sp?) fittings. Thought I would save that aggravation for a later day but maybe not?
Hey....Thanks for the reply. I bit the bullet and wired hers internally that weekend. I knew that was going to be the case but was feeling lazy on the wife's bike.
They look and operate great.......this winter she may get my 508's and I might take her 518's. I may have to listen to some though.
I did find it can be done by grinding the wire hole larger but glad I extended the wires and did it internally.
Last edited by IndyClassic; 11-03-2010 at 07:48 PM. Reason: SDK = spelling don't count but some is just too bad
Put 508's on my 01 RKC and 518's on my son's RK. Like the 518 much better more natural wrist placement. Made no wire changes on the 508's but needed to add 6" to the 518's. Not that hard of a job & shouldn't take to long maybe 3 hrs start to finish. Make sure you replace the upper handlebar mount as HD's oem is junk...
I just finished my 518 install today. I ran the wires internally and extended them 4". Easy as pie, except that the magnum brake cables I got were the wrong size. The clutch worked well though. Called Dennis Kirk to exchange the cables and the right ones should be here in a week. In the mean time the stock brake lines just barely fit, and I will be able to ride her. Thank goodness.
Thanks Jim
Sgt Big Jim,
The stock TBW wires are more than long enough. You do not need an extension. After the change to my 518's there is still 4" or more of slack in the nacelle. I had a hard time deciding between the 518's and the 508's. I had beach bars on my '98 Fatboy, and I loved them, but I read enough complaints from other forum users about the 508's that I went with the 518's. Most said the 508's are too much like holding a wheel barrow, and the wrist angle is very unnatural. I went on a good long ride yesterday, and the comfort change is unbelievable. I am finding the bike easier to throw in and out of turns too. The change to the 518's wasn't too hard, but I have an electronics background, which helps with the wiring. Removing the pins from the connectors can be a little bit of a pain, but just be patient and they will come loose. I used a paper clip that was just small enough to fit in the hole to release the pin. Push the paper clip in, and turn it slowly to hit the sweet spot to release the pin. As always, get the sevice manual and you can save yourself a lot of heartache.
Big Ick,
I got a magnum clutch cable, but got it at stock length. It is long enough, and actually seems to fit better than the stock bars and cable.
Big Ick,
