PCV Auto Tune. To accept trims or not
I am running the PCV and AT with the switch like iclicks. I tell you I am remarkably impressed with the map AT has made. Jamie was very instrumental in getting me a good base map I then showed him my map progressions and he provided me a new base map to start with. My bike runs better than it ever has and does not ever miss a beat or sputter back fire. iclick was good to me too on comprehending how the AT works and what he said above is all true but hard to fathom when your starting out with the AT. Keep at it with Jamie he will get you straightened out and there are guys here than have good info also that are willing to help thanks iclick!
All that said, nothing's perfect and I wish I could get city mileage up into the low-40's, but that seems impossible with this bike. I'm in the range of 37-38mpg in the city, and I can't quite get a grip on why I'm there when my old carbed Evo RK would get 46mpg city on a bad day. It just doesn't compute, but I don't know what else to do.
I wonder if leaning 20-60% TP some might help, as in city riding we're in the throttle more than cruising on the highway. If I do it will feel a bit flatter in that range, but it might be worth playing around with. Has anyone done this? I'm at 14.2, 13.8, 13.2, 13.0, and 13.0 from 20-100% TP. I've noticed that I can mostly stay at 20% and below if I try, so I'm not sure why mileage is so lousy in the city on this bike. It never has been, so I can't blame the cams.
Sickbagger, I'm firmly in your camp. At the risk of sounding giddy or euphoric, I marvel at how well this bike runs every time I ride it. Like you I have no flat spots or hestitation, and outside of some gurgling at 5% TP under low load from the lean AFR's it runs flawlessly. I could add some fuel there to get rid of it, but I won't since it isn't an issue.
I know it just shows how crappy the bike ran stock, with the Vance and Hines Fuel Pak was a little better, with the PCV ran good and much cooler, with the auto tune no comaprison to any of the above mentioned. It is like your giddy or your nuts tiggle or whatever these cams and PCV with A/T man she runs with authority and just runs excellent.
I am getting about the same but have found myself letting this go. The way the bikes runs, the tempratures, I can tell she is just flat A$$ happy. Fuel mileage has not been a problem, yes it goes quick running around town but there are plenty of gas stations. On the long hauls i get good enough gas mileage and may even richen that up a bit. I can go on the highway a little over 200 miles most anyone I am riding with needs gas already. I will probably knock the AFR's back down a .3 which would be what Jamie had set me up for. I leaned it out a .3 from Jamies map but when it is hot every now and then you can hear a little noise say n she could use a little more gas. I don't want to flip the switch to the 13.0 because milage will go way down but she will be cool we know that. I save that for when I really need it but have used it and quess what? Its F N Cool!
I now why its lousy in the city you think you at 20% but your rolling through many different ranges and moving probally a 1000 lbs!
Again thanks for all your help on those time you just told me to call and all of the emails. It took me a bit to really fathom what is going on and you said I had a pretty good handle on it. I like my system now...no I love my system now!
Here's what I have on an '09 with 255's. Remember that the PCV adds/subtracts from the existing ECM timing, so you'll need to go into a stock configuration in SERT and add these values to it. Hope it helps. My '07 goes up to 4° at 100% TP and 3500+, but stays at 3° at 60-80%.
