Clutch: At what point did you guys beef it up or upgrade to aftermarket ?
Old 08-24-2010, 05:16 AM
Silverearl's Avatar
Silverearl
Silverearl is offline
Okay, sounds good but I have on 06 and have some slippage in 5th. I am using all sin in all holes. I have heard that would make a difference. But I would like a stronger clutch. So where can I find these SE springs and how easy is it to install?
Old 08-24-2010, 06:31 AM
BadPiggy's Avatar
BadPiggy
BadPiggy is offline
I'd be more apt to believe your clutch isn't adjusted properly.
The stock clutch should hold fine on these milder builds.
The SE clutch spring is a HD part.
Pick one up at your local HD dealer.
Pop your derby cover off, remove the stock clutch spring, install the SE clutch spring, install derby cover.....that simple.
Old 08-24-2010, 06:36 AM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
I'm also just running the SE spring.
Old 08-24-2010, 07:32 AM
smokindave's Avatar
smokindave
smokindave is offline
+1 on the SE clutch spring, easy install.
Old 08-24-2010, 09:04 AM
Silverearl's Avatar
Silverearl
Sounds to easy for it to be an HD.
Old 08-24-2010, 09:12 AM
Avalanche_Mutt's Avatar
Avalanche_Mutt
Avalanche_Mutt is offline
Any one have a part # for the spring?
Old 08-24-2010, 09:17 AM
cmcsns's Avatar
cmcsns
cmcsns is offline
Location: Beverly Hills, Fl. Swimmin pools. Movie stars
+2 on the SE spring, with a properly adjusted clutch
Old 08-24-2010, 09:30 AM
Certified Drunk's Avatar
Certified Drunk
Certified Drunk is offline
Originally Posted by 35th_superglide
Did you remove the primary cover or do it through the primary cover?
You have to remove the cover,
Old 08-24-2010, 09:39 AM
paguy's Avatar
paguy
paguy is offline
25,000 on my 07 RKC. Didn't like the way the clutch felt from day one. Couple weeks back changed out to an SE clutch with spring. I know the initial problem was the spring, but didn't want to mess with clutch for the next 30,000 mi. All the difference in the world.
Old 08-24-2010, 08:25 PM
joe98's Avatar
joe98
joe98 is offline
Thankyou to everyone. Your help and advice is always appreciated. Think I'll ask the dealer about the se spring on my next visit.
Quick Reply: Clutch: At what point did you guys beef it up or upgrade to aftermarket ?
