Lowered SG 2010 w/ Progressive 10-2003
Hey Everyone,
I lowered my SG and put SE Heavy fork oil in. Because this kit can lower the front up to 2" I added a .5" spacer. Now she looks right, almost level. Test ride was great. No nose dives under braking, more stable in the corners.
When I measured the front of the frame compared to the rear it was about an 1/8" lower in the front.
Should I raise the front a little to make it higher than the rear, because everything I read says the front should be higher? I don't know why?
If I don't what will happen?
Everyone's input is appreciated. Thanks.
Daddy Rabbit
03-16-2010 05:52 PM
10, 102003, 2003, 2012, flh, harley, install, instructions, lowering, part, part102003, progresive, progressive, progressivepart, spacer, ultra
