bike cutoff troubleshooting tips needed
Check your IAC valve it worked for me take a look at this forum post https://www.hdforums.com/forum/touring-models/527338-07-idle-issues.html
Usually a good idea when problems start after you have changed something is to check what you changed. Do the wheels spin freely, is it hard to push the bike around?
Also pull the spark plugs and check them for an indication of the bike running too lean.
Could be various causes, but I can't think of any related to wheels.
Also, make sure the wheel spacers are in correctly. The stalling you described sounds like typical '07 idle problems, and this is discussed in the thread Neweb posted. This is probably unrelated to your possible wheel-dragging problem.
Did you also change the brake pads at the same time? Sometimes these can be a bit snug and drag a bit for a while after changing them. Mine did this after the last replacement this past spring. If they're dragging too much I would wear them down a bit by hand. A good method is to scrape them against the concrete in your driveway until they fit properly. This sounds crude but it works.
