Loose Breather Bolts
I had some oil on the SE air cleaner backing plate and figured it was an o-ring or something. When I pulled the plate I noticed both bolts were loose and there was only half an o-ring at the front cylinder head.
Then I noticed the threads in the front cylinder head were gone. I assume it was from the bolt vibrating and wollowing out the threads. I had to put in a helicoil.
Moral of the story is to check your breather bolts if you have any seepage on your backing plate.
My old shovel used to have something vibrate loose or fall off on any long trip. Now I use torque wrenches.
Just did the air cleaner before the fluid changes, and when I pulled off the cover, 2 of the 3 screws holding the filter on fell out and were between the filter and cover. I have had oil coming out of the air cleaner after I noticed oil spots on the rear cylinder exhaust cover. I remember when I put the new filter on I did not put blue locktight on the screws.... we'll see if that helps.
xnysgt
Milwaukee Eight (M8)
14
12-17-2018 01:50 PM
