2010 Limited 103 cid Dyno Run
I added V&H Power Duals, Monster Rounds and a high flow air cleaner. The dealer did the race tuner and set up. No before numbers of course but after all was installed I had 78.3 hp and 91.2 Torque. I took it for a spin and it sure sounded good. I did have three very slight backfires on deceleration after extended high rpm run in a lower gear and letting off. I was basically trying to see if it would. After the first 30 miles it was fine. Does the ecu learn? Also how do my numbers look?
Really hard to compare as dynos read different. If it feels good you should be happy.
Without an AFR readout, it's impossible to tell if it's a good tuning. I really don't understand why more guy's don't demand their tuning service include the AFR on the dyno printout after generally paying hundreds of $s for the service. I think guy's are getting ripped off if their final print out doesn't include the AFR.
In fact I demand that I get a print out of the AFR for both cylinders. To be honest, the AFR read out is far more important than the final hp/tq #s since that's the only way to know if lot's of power was left on the tuning table or whether the tuner has the bike on the "edge" of performance and the first bad tank of gas could be it's last or whether the engine is spot on for both strong performance, reasonably fuel economy and longevity.
Guy's.... demand that you get a print out of the engine's Air Fuel Ratio that goes with the tune before you ride out of the shop. You paid for it.
I will give them a call next week and see if they still have the information, I'm guessing the answer will be no. Anyone know of a good tuner in the Houston area?
You just got it tuned and your looking for another tuner?
Try Danny at Danny's Cycle's in Montgomery. He tuned my bike and I'm very happy with it. Over 60,000 miles since he tuned it. Still runs great and I get 44 mpg. Talk to your tuner before he tunes and discuss your riding style and what you want out of tune. He'll tweak it accordingly.
http://www.dannyscycleshop.com/
Don't chase numbers. You want the bike to run right for you. That's all that's important.
